Gas tank leak
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Gas tank leak
What is the plan for removing the tank that is there now ?....if that comes out then why can't a new tank fit right back in the same spot ?
- Been thanked: 1113 times
Re: Gas tank leak
Matt1989Carver3807 wrote:Source of the post .... 70 gallons translates to about 560lbs. or about 4 or so adult passengers. ...
70 gallons of gasoline would be more like 420 lbs, but you also have to figure in the weight different of a 70 gallon tank vs a 140 gallon tank.
If you could get a 70 gallon one in there past the engine, could you fit a second 70, or even two smaller (say, 60 each)?
- Matt1989Carver3807
- Has thanked: 13 times
- Been thanked: 3 times
Re: Gas tank leak
/ Happy to accept your 6 lbs/gallon number. Aluminum tank weight is perhaps not a concern because it is offset by the weight of the alum. stbd tank.bud37 wrote:Source of the post Can you get two smaller tanks in that space easily. I ask, because if you consider the boats value, then a complete boat has more value. A US gallon of gasoline is just over 6 lbs depending on the density, so your 70 gallons weighs around 430 lbs not including the tank, so that is much less, maybe that helps your thinking here.
The problem with installing two smaller tanks is that they would have to have a pipe connection at the bottom of the tanks, otherwise they would need somewhat complicated fill and empty plumbing set up to function properly. I have not yet determined the size(s) of the smaller tanks.
As mentioned before, removing the old tank could be done by (1)moving the engine and black water tank and replacing them (2)cutting a hole in the side of the boat and repairing it or (3)cutting the tank into pieces and removing it piece by piece. Thanks for your comment.
Re: Gas tank leak
Re: Gas tank leak
Matt1989Carver3807 wrote:Source of the post .... The problem with installing two smaller tanks is that they would have to have a pipe connection at the bottom of the tanks, otherwise they would need somewhat complicated fill and empty plumbing set up to function properly. ....
You'd definitely not want to put a connection at the bottom of the tank. I was thinking an auxiliary fill and then an "a/b" valve on the feed to the engine. It is a complication but gets you back closer to the original config without having to cut the side of the boat.
- Been thanked: 654 times
Re: Gas tank leak
Re: Gas tank leak
So, it would then appear the "hole" is probably most likely at some time. The alternatives by comparison appear somewhat more untested. Thanks for your comments/assistance.
Re: Gas tank leak
Re: Gas tank leak
Re: Gas tank leak
You should get good measurements on your current tank and the space it's in. You might be able to find replacements that would fit even if they're a little different in capacity or dimensions, but at a much lower cost than an exact replacement. Once you find one that fits, make sure you check the fill location to see if that would be usable with where the hull fill port is.
Here is a great site to check:
https://www.greatlakesskipper.com/motor ... t=5793&p=1
if you can't find one that's a really close fit, then it might be better to just get a custom one made to the OEM specs.
