Most economical cruising speed
- CruiserSteve
- Vessel Info: Carver shopping with Aft cabin
- Has thanked: 4 times
- Been thanked: 2 times
Re: Most economical cruising speed
Fuel consumption data, twin 8.1 big blocks. I joined this forum months ago because I am shopping for a Carver 390, 400 or 404. I currently own a Regal 400 Commodore. This boat is LOA 42', beam of 13'1", approx. 17,000 lbs. As mentioned previously in this topic the engines have more to do with fuel consumption than which boat they are in, therefore i am sharing what 8.1 Horizons get in my Regal. This boat was re-powered around 2009 with Mercruiser 375HP MPI 8.1 (496CI) and new ZF Huerth V-drives.
Here is my info. I wish I would have recorded the gph at 3200rpm, which is a good cruise speed but when reviewing photo's and video's of my gauges over the past season I don't see where I recorded that RPM/speed. I was surprised at the change in fuel usage at the lower speeds, 2mph can make a rather big difference. At higher speeds I will need a bigger wallet.
MPH recorded by GPS (Navionics and Simrad). Consumption data by Mercury SmartCraft gauges with fuel flow. The engines have 230 hours on them. Props are 19 X 22.
Fuel on board was 160 gallons, water tank about 100 gallons, waste tank empty. Very smooth water (no wind), 74 degree's air temp. GPH is for both engines.
6.0 mph is 3.5 gph (900 rpm) All GPH listed is total fuel consumed, both engines are added together.
8.6 mph is 5.6 gph (1420 rpm)
9.5 mph is 7.2 gph (1610 rpm)
16 mph is 20.6 gph (2540 rpm)
37 mph is 54.0 gph (4200rpm)
The 400 Commodore is an express cruiser style boat. No Aft cabin, no Flybridge.
- Been thanked: 1113 times
CruiserSteve wrote:Source of the post...
You could do the ENTIRE Great Loop, filling up less than 26 times!!!
- CruiserSteve
- Has thanked: 602 times
- Been thanked: 1311 times
CruiserSteve wrote:Source of the post As mentioned previously in this topic the engines have more to do with fuel consumption than which boat they are in,
I think you will find that the boats design, LWL, super structure and especially the hull design ( displacement trawler versus flat aft vs steep deadrise ) has a great deal to do with fuel usage. Remember fuel usage is a result of the amt of hp being applied. Some hulls require less HP to run at the same speed as others due to waterline length and hull shape, just the way it is IMO. The eternal boating struggle....
