First Time Winterizing
AlexB
Vessel Info: 1992 Carver 33
Re: First Time Winterizing
Postby AlexB » November 1st, 2022, 11:30 am
Does anyone know how many qt of oil does a crusader 454 hold? Or should I keep pouring it in and look at the dip stick?
Postby km1125 » November 1st, 2022, 12:44 pm
It would be typically about 5 or 6. Check the dipstick after you've run it, especially if you've replaced the oil filter.
If you are unsure, you can start with four and run it for a few minutes and then check the dipstick and start filling from there to get to "full". Don't overfill. Much better to be slightly under full than any over full, as long as you're above the "add oil" mark.
Has thanked: 603 times
Postby bud37 » November 1st, 2022, 1:09 pm
Yep, always go by the stick .
AlexB
Postby AlexB » November 1st, 2022, 3:11 pm
Ok will do. thank you
Postby tomschauer » November 1st, 2022, 3:27 pm
my 1998 merc 454's take seven quarts when changing oil and filter.
As mentioned, I would put at least 5 in, run for a minute and check the dipstick. Sometimes you don't get all the old oil out if your siphon tube isn't in just right.
Users browsing this forum: Google [Bot] and 39 guests
