Installing Flooring in Carver Mariner
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Installing Flooring in Carver Mariner
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
- amanphoto
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Around here, I couldn't do dark..as its usually already dark here...
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
amanphoto wrote:Source of the post Thanks for all the ideas and pictures. I'm going to remove the carpet and prep the area the best I can. I want glue down some sort of vinyl flooring without any trim pieces around the hatches. A nice clean look. I'm not sure what pattern of flooring to use. My walls are wood and I don't want to add a wood design to the floor that will compete with the other wood in the boat. I was thinking of going with a textured vinyl in a neutral color. I found something I like at the Box stores. I'm not sure that it can be glued down. Any suggestions on what to use? This is a Photoshop sample of what I was thinking of using.
I will post some pictures of what I done over the weekend for same project. I used vinyl planks from Lumber Liquidators, using LVT adhesive from home depot. Worked well for me. There are many hatches on mine, and did not want to use anything around. I'll post how and what I did with some pictures next week.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
You can check out Stark's custom design process at: https://www.starkcarpet.com/services/cu ... velopment/
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Has thanked: 602 times
- Been thanked: 1311 times
That is a nice clean look, I like it....will be interested to see how you handle the floor hatches......
- cpoint
- amanphoto
I've checked with several flooring manufactures. They do not recommend installing their laminate flooring in a boat because it is not climate controlled. Has anyone had issues with installed flooring warping or releasing from heat of cold?
- cpoint
