Water in forward and mid bilge
Re: Water in forward and mid bilge
Postby mjk1040 » June 4th, 2017, 12:07 pm
They make critter ends for pvc pipe. Measure the inside diameter and see if one would fit right inside the exhaust itself and then silicone them in?
Postby bud37 » June 4th, 2017, 12:49 pm
dsolo wrote:Source of the post Here is a pic of mesh
I would like to address the same thing, but boat is in already though, ( furry little devils are everywhere this year )......I wonder if you cut that to fit the opening with lets say a 1/2" lip around, you could fold over , push it in then two part epoxy in place with a bead over that lip....I have stuck transducers down with that , stuck props to hubs etc. What say you ??....... :beergood:
Postby mjk1040 » June 4th, 2017, 2:37 pm
All the high water, the little critters are looking for a dry hole!
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Postby dsolo » June 4th, 2017, 7:12 pm
Boat is in water. Applying epoxy would require pulling boat. Cost is between $3 & 400. I am still thinking a shape cut to the exhaust port shape but over size would hold in place. I just don't know the force of water at WOT? Would it blow the screen out?
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Been thanked: 490 times
Postby waybomb » June 4th, 2017, 8:06 pm
Are these round holes?
A neighbor takes Margarine containers that fit snugly, and puts them in the holes. He has a hole in the middle of the bottom with a line tied with a knot on that back side, so he can remove them.
Postby mjk1040 » June 5th, 2017, 4:42 am
Brilliant idea! I've seen some that use small fenders to plug the exhaust too! Butter tubs a lot cheaper and u get to recycle.
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » June 6th, 2017, 8:24 pm
WOW the damage they cause. Must be environmentalist. They don't like sink boats?
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby mjk1040 » June 6th, 2017, 8:30 pm
We have an issue with mink here in NY. They grab dinner and climb in the boats thru the vents for the bilge on the 355's & 356's. Man do they stink too. Worse than a skunk, not to mention the rotten dead fish they leave behind. We all had to have screen covers made so they can't get in that way anymore.
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » June 6th, 2017, 9:04 pm
Here is they're work.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby tomschauer » June 6th, 2017, 11:24 pm
Wow, fingers crossed, but so far no such critter issues down here!
