121805eg c-charger 5000 out of commision
- Has thanked: 602 times
- Been thanked: 1311 times
Re: 121805eg c-charger 5000 out of commision
Now I will add that this will hinge on the wiring not being previously altered, you will find out.
- Been thanked: 1113 times
cpoint wrote:Km, thanks I thought about that as well as I was talking to a friend of mine and will check next time. Also I was thinking connecting direct to battery as the tech support mentioned to see if that works. But checking the fuse probably easier.
If you make the runs direct to each battery, you'll also need to place a marine-rated ignition-protected breaker in the line somewhere near each battery. I think the spec is within 6-8". This protects the wire in case there is a short upstream and the battery discharges though that wire.
cpoint wrote:Source of the post
.... Also in your comments about switch, I believe all 3 batteries are charged regardless of the switch selection, but is restricted by the 3 switches as I highlighted with red markings on the attached picture. The only reason I am making comment about the switch (1, BOTH, 2) is, when I have it's on #1, all is well and shows battery is being charged and discharged appropriately. but on #2 it is not charging, so either fuse, line is an issue most likely. I am hoping line is OK, because it's been fine all this time, but maybe fuse got blown when original charger stopped functioning.
Those "switches" by your main switch (the 1,both,2) are actually circuit breakers to protect the lines from the charger to each battery circuit. They likely tie in at the back of the 1,both,2 switch where the battery cables are, but as Viper said, the don't depend on that 1,both,2 switch or proper operation. The just bypass it. However, if you have an issue with the charger circuit going from the charger to battery #2, then if you switch the 1,both,2 switch to BOTH, then both your #1 battery and your #2 battery would be able to share the charger circuit going to #1. That would be a temporary measure to get your #2 battery recharged while you figure out what the real issue is.
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Bud,
Thank, will definitely check that first when I get back. I have no idea behind door #1
but as you say I am sure I will know what I am looking for. Will post back here once I take care of it.- cpoint
Thanks for that additional information, I was about to ask that next about temporary solution of using BOTH to charge. Because when I have it on both I did see amps going up and down depending load is put on or removed.
One other side question. this 3 week old brand new battery that got drained down to 5.7 amps, if charged is it as good as new? or is it some what damaged, I mean compared to new battery is it no longer same future capacity hold wise?
- cpoint
- cpoint
Attaching 2 images The switch was on BOTH for the pictures. Went for a walk for an hour. Battery switch on BOTH position, but really no load on them. I though #1 was charging #2 was not charging. But looks like neither is charging.
- cpoint
Where are you getting the information that neither battery is getting a charge?
Going on the little information I have, sure looks like the charger is hooked up improperly and gets switched via the battery selector switch.
Please clarify your post as it does not make much sense to me at all.
