Looking for galley sink replacement
Topic author
valoos
Vessel Info: 1981 Carver 3607 Aft Cabin "FOOTLOOSE"
Twin Pleasurecraft 225 hp V-8 diesels
Postby valoos » December 27th, 2014, 4:33 pm
is a 1981 3607 Aft cabin. Any suggestions are welcome.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Looking for galley sink replacement
Postby Lyndon670 » December 27th, 2014, 9:26 pm
You will not find a direct fit replacement sink, unless you can visit a wrecker yard. I replaced the galley sink and the head sink in my Silverton with two that I ordered from Home Depot. The barsink size will be fairly close.
It's a good time to redo your counter top too!
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Been thanked: 490 times
Postby waybomb » December 28th, 2014, 8:49 am
Great Lakes skipper on ebay is a fantastic source. They also have a store in Franklin Wisconsin called kendors.
Also a great time to install granite and a real faucet.
Papua New Guinea
PNGTaubada
Vessel Info: Carver 466 MY 2002
Postby PNGTaubada » April 22nd, 2015, 10:40 pm
If it's just dull and no damage to the ceramic, you can get rejuvenator kits that will save you lots of $
Mommaboyd
Vessel Info: 2001 Carver 396
Cummins deisel
Postby Mommaboyd » June 8th, 2016, 2:14 am
Waybomb, did you replace all granite? Was yours "sandwiched" in between counters and end tables like ours is? (2001 396)
Postby waybomb » June 8th, 2016, 12:03 pm
I installed granite, well, had it installed. I took the drop edge off, and installed the granite right on top of the old formica tops.
I have pix in my album in the sig.
We decided that having all that surface area to glue to instead of just the edges of the cabinets would be a good idea.
So the top of the counter is now about 1.5" higher that original.
Users browsing this forum: No registered users and 60 guests
