Engine Alarm: Normal Temp, Normal Oil pressure
Topic author
Dan_Fuller
Vessel Info: 2008 41CMY
Hard Top
Blue Stripe
Postby Dan_Fuller » May 28th, 2013, 5:03 pm
This past weekend I took my 41 CMY out for a 20 mile trip. On the way home, I had an engine alarm go off on my port engine when I pushed the throttles up past 2800 RPM. I immediately shut it down and started looking things over. I got normal temps and oil pressure, so I started up again. As long as I stayed below 2500 RMP it was OK, no alarm. I tried throttling up again and same thing, after about 30 seconds the alarm went off. Came home at low RPM around 1800 RPM with no problems.
I have Volvo D6 370s and the alarm on the led panel just said check manuel. I'm sure it must be something silly. I did have the oil and filters changed the week prior. To my knowledge there is no fuel leak.
Anyone have this issue before?
Dan Fuller
2008 41 CMY
Dan Fuller
2008 41 CMY
Been thanked: 490 times
Re: Engine Alarm: Normal Temp, Normal Oil pressure
Postby waybomb » May 28th, 2013, 7:54 pm
I don't know a thing about your Volvos, but....
Oil full? You would be surprised how much oil is not in the pan when running. A bit low and it could drive a low level alarm.
Topic author
Dan_Fuller
Hard Top
Blue Stripe
Postby Dan_Fuller » May 28th, 2013, 11:42 pm
I didn't think about low oil level because we just changed it. You could be right. I'll check it when I gent back down this weekend .
Thanks!
Dan Fuller
2008 41 CMY
Nplbw
Vessel Info: 2005 Carver 411 CMY Volvo penta d6 370 hp
Postby Nplbw » July 6th, 2013, 11:22 am
I am not sure if you have gotten an answer but I believe it is water in your fuel. You will need to drain the racor and engine fuel filters. There is pre-warnings on your EVC, if you have it, there are small lights that blink. Then your warning gauge will flash and finally the audible alarm will sound. Good luck.
Users browsing this forum: No registered users and 50 guests
