3807 Aft Deck seating ideas?
Topic author
Wauchopia
Vessel Info: 1990 Carver 3807 Just big enough for a family of 5 including 3 boys. You DEFINATELY need a full size fridge if you're cruising with these fellas.
Postby Wauchopia » March 18th, 2015, 8:14 pm
Any suggestions on what has/ has not worked well for you? We just picked up this 1990 3807 and apart from the fridge and the bar (not that I'm complaining!), there is nothing there. As there is a banquette in the galley, do we really need another table and chairs? Maybe just chairs and a coffee table? I'm open to ideas and photos if you have them. We're generally travelling with 4-6 people aboard. Thanks!
Ramsport47
Been thanked: 59 times
Re: 3807 Aft Deck seating ideas?
Postby Ramsport47 » March 19th, 2015, 6:26 am
I've seen several ideas from patio furniture to "pontoon" boat seating, to standard deck chairs. Pontoon boat seating is probably the most comfy, but certainly the hardest to move around, if you need to.
Kenny
T-Merc 350 Mag MPI (300hp)
Washopay
Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers
Has thanked: 23 times
Been thanked: 5 times
Postby Washopay » March 21st, 2015, 8:57 am
Hey Kenny Whaddya mean by pontoon seating? Thanks for the input!
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 29 times
Postby CYO Admin » March 21st, 2015, 10:58 am
Google "pontoon seating". It's modular seating that gets bolted to the deck but there is no reason you would need to bolt it down unless you frequent rough seas.
VapinBill
Vessel Info: New owner of a 1989 3807.
Has thanked: 8 times
Postby VapinBill » August 4th, 2016, 7:38 pm
The one we are about to purchase have these.
1989 3807 Carver Aft Cabin
Twin, Crusader 7.4L (454 cid V-8)
Detroit Michigan
Postby tomschauer » August 4th, 2016, 8:11 pm
I do believe those are pontoon seats that someone had the Carver logo added onto.
VapinBill
Postby VapinBill » August 4th, 2016, 8:39 pm
Thanks for the info, Tom.
Detroit Michigan
Postby tomschauer » August 4th, 2016, 8:52 pm
If this type of seating interests you try Overton's.com
You can get custom colors and such at a reasonable price.
Been thanked: 490 times
Postby waybomb » August 5th, 2016, 11:25 am
I knew a guy with a 48 Hat. He had custom seating made. Fiberglass frame with wrap around seating on top. Under the entire seating area was storage. When it was all done. It looked factory correct. The fiberglass wad painted with the same imron as the hull, and the vinyl matched the helm vinyl.
Very proper.
