Bilge pump float switch wiring
transdktr
Vessel Info: 1988 27' 2757 montego twin 4.3lx w/alpha drives 850 hours. Cape Vincent New York
Postby transdktr » May 29th, 2015, 10:56 pm
88 2757 montego, looking for wiring diagram that shows the float switch operation, all the ones I've seen don't show it. Pump doesn't operate on automatic, fuses are good float switch is good. Trying to figure out how it turns the pump on electrically. Thanks, Ray
Been thanked: 490 times
Re: Bilge pump float switch wiring
Postby waybomb » May 30th, 2015, 9:17 am
Does it work with the helm switch. If so I'd be very confident you have a bad connection at the float switch wires or a bad switch.
Users browsing this forum: No registered users and 46 guests
