Engine Water Pump - Impeller Replacement
mrsparkj
Topic author - Scurvy Dog
- Vessel Info: 1987 Carver Aft Cabin
- Has thanked: 3 times
Are there any good tips/videos out there regarding changing an impeller on a Crusader Engine? I looked on You Tube, didn't find anything specific to my type of engine. Access to the pump looks kind of tough, cover has a belt on it.
Any advice would be appreciated.
Thanks.
Scott
- waybomb
- CYO Moderator
- Been thanked: 491 times
Re: Engine Water Pump - Impeller Replacement
If you find pieces missing from the original impeller, you'll probably have to pull the hose going to the oil cooler and retrieve those pieces.
mrsparkj
Scott
http://www.boatinghowto.com/content/cru ... -pump-178/
- waybomb
- CYO Moderator
This spare pump popped up today. I am in no way associated with or know the seller.
http://www.ebay.com/itm/Crusader-Sherwood-E35-Raw-Water-Sea-Pump-220-270-305-350-502-V6-Engines-97179-/252054018837?hash=item3aaf971b15&vxp=mtr
mrsparkj
Thanks for the great info on the e-bay info! So, I had a buddy come and help me trouble shoot.....to find out it was just an anti-freeze problem and not the pump! When I told him that the engine temp would climb to over 200 in idle but when I set around 1000 RPM it would cool back down to 160 he thought I may have a thermostat problem. He walked me through the cooling system for my familiarity and when we open the heat exchanger noticed there was no anti-freeze in the starboard one. PORT heat exchanger was full. How it go through the survey I will never know. We filled it up, ran for 15 minutes, starboard engine stayed cool at 155 and we didn't notice any leaking from that area. So, some $$ saved at this point. However, since it has been almost 2 years since the original impellers have been changed I think this winter while it is sitting (use a bilge heater during the winter months) I will send to this person listed on this site to "rebuild" both pumps for "preventive maintenance" for next spring.
Again, I really appreciate you help, but wanted to provide feedback. High learning curve as a new boat owner, kind of fun!!
Scott
- waybomb
- CYO Moderator
mrsparkj
Concur. Having a mechanic come out next week.
Question for you. Ran the engines the other day at idle for 30 min, temp never exceeded 160 on both. Took it out for about an hour, RPM up to around 1500, temp stayed steady between 160-170.
2 days later I took the boat out (ie. today), and before I started things up, checked heat exchangers, fluid levels all the same as they were 2 days ago. Oil sitting good too. Felt all hoses, no noticeable leaks/moisture (to indicate leaks). Range engines today....good at idle then went out for about an hour, running at 1800 RPM. Port engine maintained 160, Starboard engine (one with problem stated above) got up to 180-190. Never exceeded 200. Had some friends onboard who are boat saavy, and they said that spread is ok, and the higher temp should be fine. Checked fluids again after it cooled down, normal, no indication of leaking. Trying not to be paranoid, but trying to learn at the same time. Will continue to watch, just wanted to get your opinion with what is going on.
Thanks in advance.
Scott
- waybomb
- CYO Moderator
I like 160. 180 not so much. Could simply be gauge error as well, but the low coolant would have me worried.
Users browsing this forum: No registered users and 40 guests
