Winter Battery Storage
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Thanks in advance
Fraser
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Winter Battery Storage
..Aaron
SeaDragon
- waybomb
- CYO Moderator
- Been thanked: 491 times
But now they are all inside heated. Everything stays on the boat.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Hope this helps.
While it was the popular thing to do at one time, removing the batteries for winter is old school but there are still a few old school misconceptions about batteries that some find difficult to let go of like having to put batteries on wood instead of directly on concrete. That's okay though, what ever floats your boat and has been working for you over the years is right for you!
- waybomb
- CYO Moderator
May be old school, but as the electrolyte loses it's acidtity (=voltage) reaches H20, it's freezing point rises. All you need is a -10 day and a -20 night. Expanded cases and possible cell support damage.
Not trying to sway anybody here one way or the other, just putting my experience out there. There are several variables/contributing factors resulting in a dead battery come Spring time but a good battery put to bed properly will still be charged in the Spring and crank over your engine no problem. If it doesn't, then it was a bad battery anyway and it's best you find that out at the beginning of the season rather than later out on the water.
One should also consider the following about taking batteries home; flooded batteries don't like to be moved around too much, the less you move them the better. In some applications where they are really tight access, you're apt to do more damage than good by removing and installing them twice a year. Consider too that the average person is not familiar with proper practices and will typically overcharge their batteries throughout the winter as a result of using a cheap charger at home (battery killer) because of the need to feel that they must always be on charge to keep them "topped up"
If you feel you must take them home indoors, keep them cold to minimize discharge like in a cold room/cellar. Directly on the concrete will keep them colder (yes I said on the concrete). And if you feel the need to keep them on charge, get a smart charger, and make sure your connections are tight or you will overcharge them. Don't keep them on charge indeffinitely, just once a month if you feel you must charge them. If you are going to charge more than one at the same time, make sure you group them into similar types like crankers and deep cycle as they would be on the boat. Have fun with that
- feeez
Lots to ponder now
Fraser
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
John
- Vessel Info: 1991 Carver 28 Aft Cabin, Twin 5.7 l Crusaders
