Oil Pressure Sensor
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Oil Pressure Sensor
Postby feeez » September 20th, 2015, 11:22 pm
I have a intermittent jumpy oil pressure gauge on my port side. I have checked the connection at the back on the gauge and every thing is tight. I would like to know where the other end is connected
2001 350 Mariner with 350 MAG MPI.
Fraser
Former 2001 350 Mariner owner
Been thanked: 490 times
Re: Oil Pressure Sensor
Postby waybomb » September 21st, 2015, 12:15 pm
I think there is at least one connector between the gauge and the engine harness. This would be a large connector with many wires.
I am guessing the actual sender is somewhere down near the oil filer adapter is on the engine. This should be two wires.
Users browsing this forum: MirrorFinishPolishin and 12 guests
