length of hose?
Jeff Thornton
Topic author - Scurvy Dog
- Vessel Info: 1989 Carver 2757 Montego CDRH5049J889, 1974 Ericson E27, 1996 Avon - Sea Rider -SR6 (Rigid Hull Inflatable) and a Nordica 16.
- Has thanked: 5 times
- Been thanked: 2 times
length of hose?
I have one that the head/shower has water built up. ran the pump and the level went down but as soon as pump was shut off it rose back up again.
Can't find the tank to do a visual (Carver manuals is missing sheets) or even find the routing of the hoses to give me a hint.
It is already on the trailer in the back yard so I thought I would just do a pump out there.
If anyone would have the locator guide sheets that are referenced in my manual bout not found in section O, I would love them!
Thanks!
Jeff
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: length of hose?
T-Merc 350 Mag MPI (300hp)
Jeff Thornton
Re: length of hose?
Should I put some pink stuff (ani-freeze)in the water before I pump?
- RGrew176
- Been thanked: 470 times
Re: length of hose?
Jeff Thornton wrote:Awesome!! I will let her run.
Most certainly. When you winterize turn on the shower sump pump and dump about a half gallon of the pink stuff and let it pump out. I would rather be safe than sorry.
Jeff Thornton
Re: length of hose?
By the way, Bryan at Carver got me the missing sheet. Showed me where the pump was located. I would never have guessed it was located where it was and was direct to a thru hull. My first boat with a shower.
