Toggle switch breakers for Carver 3607
Carver83
Topic author - Scurvy Dog
- Vessel Info: 1983 Carver 3607
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
Re: Toggle switch breakers for Carver 3607
On ebay they are "greatlakesskipper"
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
https://www.bluesea.com/products/7204/A ... e_Pole_10A
Cheers All
Fraser
PS. for all you Ontarians.... "THE ICE IS OFF SIMCOE" YEEEE HAAA
- mjk1040
- Been thanked: 246 times
Mike
- Has thanked: 469 times
- Been thanked: 1765 times
http://www.directindustry.com/prod/carling-technologies/product-9181-1451345.html
- NIJORLES
- Vessel Info: 1983 Carver 3607, twin diesel D225
- Has thanked: 2 times
I cannot complain but one of the main circuit breakers has finally decided to quit working.
I have a 36 Carver 3607 1983, and I am looking for a tripple pole single toggle circuit breaker. The old one was made by AIRPAX. The hole in the main pannel is round, that in itself is a challenge.
Any hints would be very much appreciated.
Charles
https://www.digikey.ca/
or Electrosonic in Markham Ont. https://www.e-sonic.com/en.
See if you can still get a part number off your breaker. Failing that, I'm pretty sure the main source breakers on your panel are different from the individual distribution breakers for each circuit. If that's the case and you have a hard time getting the Airpax ones, I'm pretty sure Blue Sea breakers will work. Just confirm the size, spec, terminal type, and mounting configuration.
For the rest of the breakers on the panel, see the thread linked below. I posted some part numbers for units I bought from Electrosonic and there is other information you should be aware of for the individual breakers. In my case, the part numbers are for the screw type terminals, Carver used both these and the spade terminal model so you'd have to confirm which ones you have....
https://www.carveryachtowners.com/viewtopic.php?f=10&t=7544&p=59334&hilit=airpax#p59334
- Has thanked: 78 times
- Been thanked: 1093 times
NIJORLES wrote:Source of the post Hello Everyone,
Charles
Are you talking about the incoming main AC breakers? Are you sure you don't have a reverse polarity situation? In those, one of the three "breakers" is actually the reverse polarity detection and it will cause the breaker to trip and not be reset.
