Battery Charger
- Terra Nova
- Vessel Info: 2002 Carver 410 Sports Sedan
- Has thanked: 2 times
Battery Charger
Does anybody have any recommendations on a battery charger? The original charger still works but its on its last legs...
Re: Battery Charger
http://promariner.com/products/dry-mount-marine-battery-chargers/pronauticp-series/
I would use the 8D on the house bank and just stick with a 24 to 31 group start battery for the engine. Having said that, it's not a good idea to mix battery types or sizes in the same bank so adding an 8D to a bank that already has a 4D isn't ideal.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Battery Charger
14 awg - 15 amp
12 awg - 20 amp
10 awg - 30 amp
8 awg - 40 amp
You can often find a good deal on chargers on eBay: http://www.ebay.com/sch/i.html?_from=R4 ... r&_sacat=0
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- waybomb
- CYO Moderator
- Been thanked: 490 times
Battery Charger
Battery Charger
- Been thanked: 654 times
Battery Charger
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Battery Charger
Also, Vipers post re gauge is paramount.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Battery Charger
I am also using 4 golf cart batteries for my house and I installed a Victron last season and learned volumes about the performance of my battery charge (50A C-Charger). It is original to the boat and I don't believe is working very well any more.
How quickly does your quoted charger put juice back into your battery bank? Mine is almost glacial compared to what I get when the boat is running.
Fraser
g36 wrote:
> i would also ask myself how fast do i want to recharge my house bank. or do you plan
> on just recharging when running or back at the dock. do you enjoy the peace and
> quiet or the genny running? i dont know your boating habits, a 40amp charger as
> mentioned might work fine but if you are looking at a fast recharge you need to
> look into something way bigger. you definitly need a ignition protected unit if
> placed in the engine room but going outside the engine room you have way more choices
> in chargers that cost way less. i stay on the hook for extended periods so i have
> gone this route. the size of the wire and length of the runs have to be taken into
> account for safety. i have my charger mounted outside the engine room and tied
> into the main electrical 12vdc runs from the battery bank in the electrical compartment
> of my 405, as a house bank i run golf cart batteries and added this iota dls90 charger
> to quickly add amps back to my house bank when on the hook. in addition to a victron
> battery monitor it works very well for me. you may not need this much again it
> would be up to your needs.
Battery Charger
here's the link to charger and controller
http://www.iotaengineering.com/dls90.htm
http://www.iotaengineering.com/iq_m.htm
- feeez
Battery Charger
The C-charger is a 3 bank 50 amp charger. When it is running the Victron show it is flowing anywhere from 30 to 35 amps back into the 6 volt battery bank. I assume that the balance is going to the other banks. The problem is that it will do this for maybe 5 minutes or so and then stop for a while then start up again. So, if I am on the hook running my genny I am not getting very much back into my battery bank if the charger is only running for perhaps 15 or 20 minutes per hour.
g36 wrote:
> Here's the link to the manual. How many amps is the victron monitor saying your charger
> is putting out when the charger is on? This one will run at full output but is controlled
> by the iq4 controller so the batteries are not over charged. Give the manual a look
> the next size down is a 75amp which I have also had on another boat
Users browsing this forum: Google [Bot] and 30 guests
