Trim Tabs Reservoir Location?
Topic author
mphillmd
Vessel Info: 2003 Carver 444
Postby mphillmd » November 2nd, 2015, 4:49 pm
Hi
I'm new to this site. I have a 2003 Carver 444. Trying to locate the reservoir for the trim tabs. Owners manual no help. Anyone know where to find it? Thank you.
Mike
Wayne162
"Change In Latitude"
Has thanked: 16 times
Been thanked: 32 times
Re: Trim Tabs Reservoir Location?
Postby Wayne162 » February 16th, 2016, 5:10 pm
Hi Mike,
Belated welcome, if your still looking for your trim tab reservoir try looking Aft. I have a 1997 405 and I located mine under the bed in the Aft cabin. I looked through a floor panel and found it mounted directly beneath the Starboard side of the headboard against the Aft bulkhead. Mine used Tran fluid to fill.
:usa:
Been thanked: 490 times
Postby waybomb » February 16th, 2016, 6:52 pm
Wow, I missed this first and only post by mphillmd.
Hope you are still around.
Postby Viper » February 16th, 2016, 7:42 pm
waybomb wrote:Wow, I missed this first and only post by mphillmd.
Ya how did we miss this one?
As noted above, they are typically mounted close to or directly to the transom. Here is a link to a picture:
http://www.westmarine.com/buy/bennett-marine--12v-hydraulic-power-unit-with-pump-valves-reservoir-cover--264044
Sorry for the delayed replies Mike, this is not the norm here. Usually we're on it right away but I don't recall seeing this one.
