Trim Tab Fluid Reservoir
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Thanks.
- Been thanked: 654 times
Re: Trim Tab Fluid Reservoir
- RGrew176
g36 wrote:although i dont have your model this should help you locate it. the trim tab resevoir will be mounted on the transom near the tabs, not in the engine room, in my aft cabin 405 there is a lift out access panel nearest the aft wall . your carver will have the same maybe a drawer to take out or seat with a access panel or raise your mattress probably have an access panel under it and look aft you should be able to see it against the back wall
Appreciate the tip. I probably will not get a chance to check it until spring but I will look there first. Thanks.
- RGrew176
If you have an 81 and probably 82 3007 Aft Cabin that is where it is located.
Users browsing this forum: No registered users and 45 guests
