Transporting Carver 326
flynet35
Topic author - Scurvy Dog
- Vessel Info: 2000 Carver 326
RegalBeagle
- Vessel Info: 1995 320 Voyager
- Been thanked: 3 times
Re: Transporting Carver 326
- Capt Happy
- Vessel Info: 1974 16 Foot ex DFO Lapstrake Speedboat
1985 21 Foot Baby Cape Islander
1977 26 Foot Trojan F-26 Cruiser
1997 Carver 320 Voyager - Has thanked: 32 times
- Been thanked: 16 times
We recently transported a 320 Voyager across three provinces. Maximum height was 13' 6". We did need to remove the hardtop and supporting hardware. Most production boats were designed to be transported from the factory to distribution points and therefore the bridge in most cases would not need to be removed, larger models perhaps so. If you research the max height limits of where you intend to move vessel across and then contact the shipper for above ground clearances, you should be able to determine if you meet the requirements. A lowboy trailer will most likely fit your needs. The shipper we used was very professional and diligent in his care of vessel, can provide contact info if you like, I know he operates in Canada and across the U.S. Try to get someone running back empty and your costs should go down.
Cheers
