AC water pump over running
- Wkuhilltopperfan
- Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
- Has thanked: 17 times
- Been thanked: 18 times
Thank you
Re: AC water pump over running
- Wkuhilltopperfan
Viper wrote:Source of the post I think you're on the right track. The fault is likely the pump demand circuit in the control box. Does this happen even with power to the AC units shut off or just when they are powered up but not actually running and just on stand-by mode?
If the breaker is on the pump is running, it don't maker if the AC panel is turned of or not
Your winterizing has nothing to do with this.
- Wkuhilltopperfan
Thank you
- Wkuhilltopperfan
Thank you
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Wkuhilltopperfan
