fuel shutoff valves 97 355
essikr
Vessel Info: 1996 355,twin gasoline engines
Post by essikr »
Where are the fuel shutoff valves located? Twin 456 gasoline engines 1997 Carver 355.
The fuel gauge switch toggle between starboard and port plus aux tanks.How do you read the aux tank level.
Thanks for your help.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: fuel shutoff valves 97 355
Post by AaHubb »
On my '99 404 the fuel gage on one side of the dash is for the saddle tanks and the gage on the other side is for the aux tank. Each gage has a related switch to get a reading. As for the fuel cutoff valves mine are on the bulkhead forward of the engines next to the Racors.
'99 404 CPMY
SeaDragon
essikr
Post by essikr »
That explains the fuel gauges, thanks. Now if I can just find the fuel shutoffs. I have looked in all the places you would expect them to be.
Has thanked: 70 times
Been thanked: 493 times
Post by waybomb »
Not familiar with a 355, but can you get into the engine room and follow the fuel lines back? First termination after the filter back to the tank should be the valves.
fwiw - both my 1988 28 Aft and my 89 42 aft had no shut offs. My 87 36 has them but you have to get down in the engine room to see them / reach them.
trmnewt
Vessel Info: 2000 Carver 506
Post by trmnewt »
I had a 96 355 and e fuel shutoffs were under a hatch in the salon floor, just to the left of the stairs as you enter the cabin, all the way aft. A corner of the sofa sits on it1--kind of a pain
