1990 3807 heat/air issue
- Washopay
- Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers - Location: Barrie, ON
- Has thanked: 23 times
- Been thanked: 5 times
Re: 1990 3807 heat/air issue
A couple things to look for...
When you turn the stat on do you have water flow from the pump through the unit and discharging from the boat? If not you need to start here.
If you have water flow, does the compressor try to start? If not look for the high pressure switch. the older units had a manual reset switch, usually a red button on one of the copper lines near the discharge of the compressor. Some also had a low pressure switch, normally a blue button on the larger copper line near the compressor.
If the high pressure was tripped, you most likely ran the unit without water flow. If the low pressure tripped, you most likely need to clean the filter if it has one and the evaporator coil.
Give some more info and I am sure help can be provided.
Tom
- Washopay
- Washopay
Let me know.
- Washopay
- waybomb
- CYO Moderator
- Been thanked: 490 times
If so, I believe there is a three way valve in the refrigerant line.
Check the electrical connection there.
Ps, I never dug into one of these, my knowledge is from working on Thermo kings many years ago on refrigerated trailers.
- Washopay
