Generator operation
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Generator operation
Postby Agriman » May 4th, 2016, 10:25 am
Curious to know if running the genny while at cruising speed is ok. We do not anchor out and would like to run the genny to keep it in running condition. If I run it at our dock location is it wise to unplug the shore power to put a load on the genny? Could I run it with the boat plugged in?
Thanks for your suggestions.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Generator operation
Postby Lyndon670 » May 4th, 2016, 12:22 pm
Every time I leave the dock my genny is running - no issues running it at cruising speed. I can't see running it at the dock unless you don't use your boat. Also, no issues running with your shore power connected - the breaker panel will only allow EITHER the shore power or the genny to be the supply at any given time.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Postby g36 » May 4th, 2016, 12:24 pm
All that above and yes run it with a load on it
Agriman
Postby Agriman » May 4th, 2016, 3:27 pm
Thanks for the quick replies. I think what you are saying is that if the shore power and genny are both on, the genny would override the shore power. Not a big deal to just shut down the shore power when generating power.
Thanks again.
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » May 4th, 2016, 5:07 pm
One doesn't override the other. It is manually controlled by the switch at your electrical panel. You can only have one at a time.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Postby Viper » May 4th, 2016, 9:27 pm
Agriman wrote:Source of the post Thanks for the quick replies. I think what you are saying is that if the shore power and genny are both on, the genny would override the shore power. Not a big deal to just shut down the shore power when generating power.
Thanks again.
If I recall, the Mariner generator control is a manual setup (I think) but there are some vessels that switch automatically. In such a case, when the generator is turned on, it energizes a main power relay that switches the source from shore to ship.
Agriman
Postby Agriman » May 5th, 2016, 10:30 am
I do not have any manual control for the genny, so I will continue to shut off the breaker to the shore power when running the genny.
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » May 5th, 2016, 5:11 pm
Is there not a gate that only allows operation of one supply at time? The toggle on the panel should be gated....
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Postby feeez » May 5th, 2016, 5:41 pm
Mine is set up i think as Lyndon has described. As soon as the genny starts it overrides the shore power. Lots of clicking of relays as it comes on line. After the genny is shut down the relays return to normal.
I have also run mine while underway..... no issue, just make sure you are outputting water from the genny exhaust and you are good to go.
Fraser
Former 2001 350 Mariner owner
Postby Viper » May 5th, 2016, 9:20 pm
Must be as I described above with auto switching, that's why you hear the relay. Couldn't remember the Mariner set up.
