A Question For The Battery Gurus
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Battery #2 I also placed on my charger. When you first put a battery on the charger it does a battery check then charges if needed. The 2nd battery the charger went into check mode and within a few seconds the led gauge on the charger lit up and showed that the battery was fully charged. I had intended to buy 2 new batteries but the NAPA store only had one in stock. Since the 2nd battery seems to be in good condition I am going to start the season out with it and see how it holds up.
The location of the batteries is between the engines on this boat. The aft battery was a chore to get out because of its location so that is why I decided to replace a Group 24 battery with another Group 24. There is no way that I could muscle in or out a Group 27 or 29 where the aft battery is located. The forward battery is located far enough forward that I can easily pull out or place in.
Now to my question. If the remaining battery that I have decided to keep on should need to be replaced could I replace it with a Group 27 or 29 battery? Is it OK to mix battery sizes in this application. Can I have 1 Group 24 battery and one Group 27 or 29 battery working with the Group 24 battery. Or is it best to keep both batteries the same?
When I had my Bayliner 3055 Ciera all 4 batteries were the same Group 27's and I never had any battery problems.
Thanks in advance for your responses.
After Taxes
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
Re: A Question For The Battery Gurus
Your post leaves a few questions. It sounds like you installed a deep cycle battery, as your engine cranking battery. Is that the case? Respectfully, don't use a deep cycle for cranking.
Get a good cranking battery for your engine(s).
If twin engines and separate batteries, then generally, those two start batteries may be different brands or even size.
If your other batteries are for the house system, then they must be deep cycle batteries, and if using two batteries for house, they must be the same size and type, and preferably the same age. Use the very largest deep cycle for house, that you can cram into the space. Dual house twelve volt batteries are wired in parallel.
If you are starting fresh for the house batteries, take a look at using two or four golf cart batteries, such as Trojan six-volts, however get expert advice, as six-volts must be wired in series to produce twelve volts. Golf cart batteries provide many more amp-hours of service between charging.
I do realize many boats are wired differently, and some even share the house systems (lighting, etc.) with cranking. You need to fully understand your personal boat situation first.
Happy boating friend. I trust this helps.
MerCruiser MX 6.2
Lake Simcoe, Ontario
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
After Taxes
They are marketed as Canking / Deep Cycle, which I found a wee bit concerning, since I wanted purely cranking. Deep Cycle have thicker plates. My buddy swears by them for cranking over his 454 GM gas engines in a Carver 356 Aft Cabin. The price at the Oshawa Costco was 134.95. The look like an Interstate battery, with water fill caps, which I like, as I can monitor the acid levels. My previous cranking batteries were the sealed variety - yuck. Great in your auto, but I don't like sealed in a boat.
MerCruiser MX 6.2
I'm not crazy about dual purpose batteries. In spite of OEM claims, they are a compromise at best between a good start battery and a good deep cycle battery. The construction requirements of each type a very different. What makes for a good starting design makes for poor deep cycle construction. The result is a compromise to end up with a battery that will serve both duties albeit less efficiently than their single duty counterparts. Having said that, one has little choice when faced with OEM wiring that utilizes the same bank to start an engine and run house loads. It's a poor design, and I wish boat manufacturer's would stop cheaping out by wiring things up this way. Anybody with this type of setup should have this on their bucket list of upgrades to isolate house loads from the engine banks.
I've never used Kirkland brand batteries. Curious to see how they work out. I don't use anything less than 1000MCA/800CCA for gassers now. Diesels are a different story of course; typically 31 group heavy duty. The only smaller rating I use is for generator applications. I typically go with 800MCA for those unless it's an older Onan MCCK with no starter where the generator windings are used to turn the engine over. For those, I also use the 1000MCA.
- RGrew176
I decided to replace all 4 of them. I purchased 4 Sears Diehard Deep Cycle batteries. I bought them just after launch in April of 2005. Every year at launch they never failed to start my boat. As the seasons progressed I often wondered will the boat start this year. I was really surprised in 2011 when they cranked as normal and the boat engines fired up. They were still going strong after 7 seasons of use.
I guess the question is, how many CCA's do you need when the weather is warm enough for boating. I agree you really need the CCA's to start your car when it is -10* in January. I am not poo pooing what anyone here posted. My Carver has a 2 battery setup. To be honest I am not sure which battery is for starting and which one is the house battery. As it is set up currently there is one positive cable from each engine going to the aft battery and from the other engine going to the forward battery. It may be they are both used for starting and house usage. There is a negative cable running from the aft to the forward battery.
I really don't want to mess with the setup as it works and my boat starts when I turn the key. I will need to spend more time going over the owners manual and see if I have any wiring diagrams that may show how the setup should be.
I want to say thanks to each of you for the information you posted.
Two schools of thought when it comes to available power IMO; EFI engine computers do not like voltage drops very much during cranking, it could cause some weird symptoms hense Merc's recommendation of 1000MCA minimum for big blocks like 454s. I simply err on the side of caution and use the benchmark for all gassers now. While carbed engines don't have ECMs to worry about, they usually don't start as easily as their EFI counterparts and because of their vintage, they typically use a different starter design that draws more amperage, so for that, I feel more comfortable with the higher CCA and have experienced way better results.
While warm temps aid in helping engines start easier, they're still boats, and they typically sit for days or weeks without being started unlike a car that is used on a daily basis. That makes a huge difference. Also consider that it's unlikely you'll get the CCA spec during regular use as this declines over time. In warmer temps, the natural discharge rate increases so when one considers all these factors, the highest CCA you can get for the footprint/battery group, the better.
Users browsing this forum: No registered users and 62 guests
