1987 carver electrical problem
eanderson560
Topic author - Scurvy Dog
- Vessel Info: 1987 Carver Mariner
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: 1987 carver electrical problem
When you turn on the generator, do you have to switch from "Shore" to "Ship" or does it switch over automatically? If it switches over automatically, it should be switching both lines/legs. If it doesn't, there's an problem with the power relay. Have you tried cycling the shore power breaker for line one on and off?
eanderson560
Viper wrote:Source of the post I'm assuming you have two shore power lines. Is there a switch or breaker at the panel that combines lines "1" and "2" ?
It would help us determine the problem if you answer the first two questions!
Also, is this boat new to you?
eanderson560
- waybomb
- CYO Moderator
Take the cover off. Be very careful. Line voltage in there.
Plug both cords in.
Have somebody start the genny. Watch the relays.
Do you know how to use a vom?
Check voltage to the two ac voltage mains.
At the relays, the two incoming cords go to them.
The genset goes to them. Yes, when on genset the two combine automatically.
One of the relays is not letting genset current through.
Or you have a bad connection at the non-air conditioning relay on the genset side.
eanderson560
- waybomb
- CYO Moderator
- waybomb
- CYO Moderator
Best way to get to it is remove the sink. My buddy's Mariner had his there.
In that location my Mariner has the hvac water pump controls.
