Replacing Sole TV's with newer digital units
Txcruiser
Vessel Info: 2007 560 Voyager, Volvo D12
Been thanked: 2 times
Postby Txcruiser » June 6th, 2016, 4:49 pm
We do a lot of cruising and more and more we encounter digital cable systems that our existing Sole TV's will not recognize. One solution is to replace with new Sole units but of course the new models are of different size than mine!
Has anyone installed just an ordinary 110V TV like we would buy at Walmart? I understand the Sole units are built especially to withstand vibration experienced on a boat but I really don't need the 12V option. We only watch at a dock or with the genset operating.
Any experiences out there regarding TV change out? At one marina where we stayed for a month the local cable company rented us a converter box to turn the signal back to analog and that worked fine. I am not aware of any universal cable signal converter but if one exists that would be the obvious solution . Thanks for any input.
Makin Waves
Vessel Info: 2006 Carver 46MY
Been thanked: 8 times
Re: Replacing Sole TV's with newer digital units
Postby Makin Waves » June 6th, 2016, 5:53 pm
Change them out, use any tv you can buy, I have Sony Bravia
Postby Midnightsun » June 6th, 2016, 7:10 pm
The problem is probably deeper than that as you are referring to "cable" so I assume cable service at the marina. Boats are normally set up to read a standard analog coax signal however these signals are disappearing very quickly. My parents who still use analog TV called me just a couple of weeks ago and said the tv no longer works. Called the cable company and they said they do not do analog anymore on their area. Had to buy them a decoder box and hook up this way and explain they need to turn on 2 items now and select an input and their channels have all changed numbers. Not exactly easy when you are 87 years old! I am sure your sole can handle digital as I see the boat is a 2007. That being said you may need to start using a decoder on board even if you have the latest and greatest which again is assuming you are simply connecting cable from the marina. Problem is one cable suppliers decoder will not work with the other so when travelling this will be an issue. I have enjoyed my Intellian Sat system for many years now so obviously I am set no matter where we go ;-)
Txcruiser
Postby Txcruiser » June 7th, 2016, 11:12 am
Thanks for the prompt responses! Yes, I am talking about receiving a signal from a marina's cable system. I have one new Sony TV onboard and it works fine at any marina so far. It is just the older Sole units that will not work with digital cable signals. Yes, I have used a cable company's decoder during one long term stay and with it the Sole units also worked fine.
"Makin Waves" response seems to say that any new TV that will fit in the space should work and that makes sense.
I have a Direct TV/KVH system also BUT it does not allow me to receive local channels (other than when I am at my home marina). I like to see local channels as we cruise up and down the East coast. Local weather forecasts are usually more indepth.
When we get settled in Maryland for the summer I'll head to Walmart or Best Buy. Small TVs are pretty cheap these days.
Thanks again.
Postby g36 » June 7th, 2016, 2:12 pm
Any digital tv will be fine ,i use an inverter if i am out and dont run my genset.dont waste money on a 12v tv.once you have replaced the tv with one that has a digital tuner you could try scanning the off the air antenna input to see what locals you receive. Assuming theres still a antenna inatalled. May suprise you. I do also have an intellion sat that works great with my dishnetwork
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » June 7th, 2016, 3:44 pm
Switch them out. Grab a TV at Walmart and install it. I just installed this 32" LCD on an articulating arm. I have a Amazon Fire TV stick in the back and I get everything streamed. Total investment was $250. I have it wired into my Harmon and Kardon home theatre system with 8 speakers in the salon. Sounds incredible.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
