Red wire on back of alternator
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Any help would be appreciated.
Re: Red wire on back of alternator
If you know how to use a multi-meter, it's an easy test to check the isolator for a failure.
- Helmsman
Viper wrote:Source of the post Sounds like they've incorporated an isolator into the charging system to charge two or more banks while keeping them isolated from each other. If it was disconnected, I suspect it either came loose, or intentionally removed likely due to a failed isolator or other charging related issue. Does the other alternator go to the same isolator?
I can use a multimeter somewhat. Can you let me know what I need to do?
The previous guy had the isolator replaced because it failed. It was done at a reputable boat yard by their most highly thought of mechanic.
