Windlass pressure arm replacement?
Wkuhilltopperfan
Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
Has thanked: 17 times
Been thanked: 18 times
Postby Wkuhilltopperfan » July 4th, 2016, 3:25 pm
This weekend the pressure arm broke on my Maxwell windlass, has anybody had to replace the pressure arm before and if so how difficult was it?
1998 350 Mariner
Thank you
1998 350 Mariner
Re: Windlass pressure arm replacement?
Postby Viper » July 4th, 2016, 6:36 pm
What model; Freedom Series 500 or 800, or something else?
Wkuhilltopperfan
Postby Wkuhilltopperfan » July 4th, 2016, 6:45 pm
It's either the 500 or 800. I got off the water at midnight last night and was spent since I had to pack and drive a hour home......basically I was to tired to look
1998 350 Mariner
Postby Viper » July 4th, 2016, 9:41 pm
Go to this link and click on the "Power and Sail" then "Obsolete Models" then "Freedom" Load the PDF file and go to page 30. It shows you exactly what to do.
http://www.maxwellmarine.com/support_manuals.php
Wkuhilltopperfan
Postby Wkuhilltopperfan » July 4th, 2016, 11:43 pm
It won't load with my IPad but I'll pull out my computer tomorrow. Thanks :captain:
1998 350 Mariner
Postby Midnightsun » July 5th, 2016, 5:49 am
Pretty straight forward, Did a Maxell 500 just this winter. I strongly suggest you unbolt the unit and service it completely in your garage. The oil seals will probably be shot and you will be lucky if there is still oil in it. Oil seals are easily replaced by the way. Good opportunity for a good lube job also.
Postby Viper » July 5th, 2016, 7:11 am
Wkuhilltopperfan wrote:It won't load with my IPad but I'll pull out my computer tomorrow. Thanks :captain:
These units aren't made anymore so when you buy the pressure arm, you may want to consider buying two as I suspect they will eventually be harder to get and more expensive. They are a normal wear item so if you're keeping the boat for a while, you may eventually need to replace it again. While you're in there for the pressure arm, check the condition of the stripper.
Wkuhilltopperfan
Postby Wkuhilltopperfan » July 5th, 2016, 11:26 am
Thanks for the great info guys!
1998 350 Mariner
