need new engine
tinbanger00
Topic author - Scurvy Dog
- Vessel Info: 1983 3207 aft cabin
need new engine
any body know where a good place to buy a remanufactured engine?...
gonna do it myself ..marina wants way to much..Rh rotation ....port engine.... 1983 3207 aft cabin...Thanks
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: need new engine
What sort of price were you given for a long block?
You don't need the whole engine, just a long block. The trailer boating magazines usually have ads from places that sell short blocks and long blocks. Don't just buy an automotive engine, get a marine clearanced engine. They run a bit looser. You'll probably have to pay the core charge because yours grenaded and is junk.
Buy a good high volume Melling oil pump as part of the rebuild.
tinbanger00
Re: need new engine
It came with a stamped sheet metal pan , like an auto engine ,the pan on the blown engine is cast aluminum.....I found a dipstick and tube that will clear the manifold ...will I encounter any problems leaving the stampped pan on the engine ,(save for rusting out years down the road) ?...........I sure dont want to pull the motor back out if I can help it
Oh by the way the cast aluminum oil pan got cracked when the engine blew up
- waybomb
- CYO Moderator
Re: need new engine
My Cougar has steel pans. Big ones, 14 quarts, but plain painted steel.
Make sure the dipstick goes to the bottom of the pan - do not overfill oil. Aerated oil is the death of an engine.
You really grenaded that engine, eh?
tinbanger00
Re: need new engine
...I think its been damaged for a while and just took a little time to destroy iself....somthing got between the timing gears and broke the cam gear.....#8 piston hit the exhaust valve ...valve cap gone,bent pushrod, piston is completely gone ,hole in head. big hole in cylinder, cracked oil pan.....just a blue puff of smoke out of exhust pipe ,no smoke or smell in salon cabin.....weird....never had that happen before....but Im learning more than I ever thought about boat engines
