AC Line leak in 444CPMY
Topic author
Boatmiester
Vessel Info: Carver 444CPMY Model Year 2002, Power: Cummins 370 Diamond Series
Postby Boatmiester » July 17th, 2016, 10:00 am
It's a 2002CPMY collecting water in rear bilge compartment. Only occurs when AC is running. There is a leak in system and its not an inoperable sump.
Any ideas?
Re: AC Line leak in 444CPMY
Postby Viper » July 17th, 2016, 7:26 pm
If it only happens when the AC is running then it could be the condensate line that's leaking somewhere between the drip tray on the AC unit and the sump. Could be a loose hose, cracked fitting at the sump, a tare in the hose, etc. The other possibility is a leak in one of the raw water lines or fittings on the inlet or outlet circuit. A small leak may not be that noticeable but if it were a large leak, you'd be getting an awful lot of water as it's under pressure, and a bilge pump would likely be coming on all the time while the AC was running.
