2000 carver 350 mariner
- Has thanked: 602 times
- Been thanked: 1310 times
The large hatch cover in the galley floor right by the wall to the head....this one had a plywood piece under the hatch cover, What is that for, is that in all ??
The air conditioning had only one controller that I could find, I am assuming from this that it is only one heat/air unit...yes??
Any comments on the 6.2 MPI Mag engines and how is to work in the engine compartment ?...Thanks
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Re: 2000 carver 350 mariner
Our 2001 only had one air conditioning control.
Ours has the 350 MAG MPI and working around down there is pretty good. The batteries are between the engines and get in the way sometimes but generally it is a pretty good space for regular checks etc.
F
- feeez
There are some other members here that have the 6.2's so I am sure that you will get some responses on that power package also.
Fraser
- feeez
Fraser
feeez wrote:Source of the post I will take some pics the next time we are at the boat and post them. Does your soon to boat have a genset?
Fraser
That would be great, as I am not much for 12v planning.....yes it has the gen ...two starts and one for the gen...and the charles 50 amp charger...probably what you started with...
- feeez
My Charles charger was not working properly so I replaced it this season with a Promariner 1250. For Batteries I moved the genny starting battery over behind the port engine. I just had to get a longer positive cable made up. Then I moved what is Battery 1 to where the genny battery was and this made room for 4 Trojan T105 6v batteries that are connected in a series/ parallel array. This is Battery 2. This setup has worked great for us as we anchor out quite a lot. Anyway, back at the boat on Monday.... pics to follow.
Fraser
