1994 390 CPMY 7.4 Mercruisers
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » August 7th, 2016, 8:13 pm
Anyone know what the WOT should be on this boat with these engines? I can hit 4,000 to 4100 max and am doing 29 MPH. Is this where I should be?
Re: 1994 390 CPMY 7.4 Mercruisers
Postby mjk1040 » August 8th, 2016, 5:26 am
Seems about right, our 1998 355 AC/MY with 7.4L Crusaders top out at 4,400 rpm and about 31 mph.
I questioned a very knowledgeable Carver mechanic why our props pitch was not what the Carver spec sheet stated they should be, he advised me that Carver would correct over or under rpm by adjusting prop pitch to keep them where they should be. I'd check your props size and pitch, they may have been changed? Mike
Postby tomschauer » August 8th, 2016, 8:49 am
My 1998 355 also tops out at 4400 @ 31mph.
Postby tomschauer » August 8th, 2016, 8:52 am
Your 94 most likely has carbs and not fuel injection. You may be at the proper top rpm. The max rpm is usually on the rocker cover sticker along with the timing setting and plug type.
Users browsing this forum: No registered users and 50 guests
