Californian 45 packing size
Topic author
Hotei
Vessel Info: 1990 californian 45
Postby Hotei » September 9th, 2016, 7:34 am
I have a 1990 Californian with 2" prop shafts. The packing nuts have bottomed out and I need to add some more packing. It's not a problem to add the packing in the water, IF I have the correct packing to add.
Can anyone tell me what size packing is used?
Has thanked: 603 times
Re: Californian 45 packing size
Postby bud37 » September 9th, 2016, 8:14 pm
There are different makers of the packing glands and they use different size packing with the same size shaft......so you may have to measure the ID of the nut and 1/2 the difference between that and the shaft size would be the size you are looking for.....2'' shaft and nut ID of lets say 2 1/2"-----diff 1/2" divide by 2, would be around 1/4" packing..just an example for you.....good luck.....you probably already know this but....... :beergood:
Postby Viper » September 9th, 2016, 8:43 pm
You could try calling Carver and give them your hull number if you don't get a definitive answer here.
Where is she berthed? Don't recall ever being in one up here.
Topic author
Hotei
Postby Hotei » September 13th, 2016, 9:41 pm
The Hotei is at Lambs Yacht Center in Jacksonville.
