Cracked riser on my 7.4 merc?
Harvester_1
Topic author - Scurvy Dog
- Vessel Info: 1991 carver aft cabin 370
- Has thanked: 4 times
Harvester_1
Re: Cracked riser on my 7.4 merc?
Harvester_1
The gasket
If it's a closed cooled manifold, there will be a blocking gasket; coolant on one side, water on the other.
Harvester_1
Harvester_1
- mjk1040
- Been thanked: 248 times
Harvester_1
Yes, we did a sea trial and also, the owner originally drove the boat to my marina from about 8 miles up river. The surveyor was top notch. I was impressed with how maticulouse he was and his professionalism as well. He noted as well as showed me what he thought to be a previously repaired leak on that riser but it looked like it was comming from a loose band at the exhaust hose that had since been tightened. He knew that the boat boat was driven there origibally and that it never overheated at all. I didn't watch the gauges that closely during the sea trial so it may have been running hot. The crack wasn't easy to spot believe me. I sat in the engine compartment after it over heated and went through the whole cooling system visually trying to figure out what i was going to check first. I pride myself on my mechanical skills. I was a mechanical engineer. Of course my mind went to the raw water pump but i found a whole bunch of parts in one of the holds filked ed with cooling system parts like.... new impellers, new pump housings, new heat exchanger caps, new and old water temp sensors...new and old oil coolers.... so, i don't think this over heating problem was new. The surveyor never saw those things and with the fact that it didn't overheat on the sea trial and it was idling in the slip after i parked it there for several minutes with no problems i don't blame him. Believe me, that crack wasn't easy to find or see. It's on the bottom of the riser and i had to pick at it with a razor knife to even see it my self. I have had stern drives do the same thing more than once where the engine would only over heat at idle but not while running up and down the river. i believe it is because of the volume of water being forced into the cooling system due to the higher rpm's. So I'm figuring this is a similar situation. But i wont know if that is the only problem till i get the riser replaced first. The fact that i found all those replacement parts in that hold makes me think that's not the only issue. Keep in mind, this boat is imaculate. The original owner really Took care of this thing. I even have the oriiginal build sheet from carver from 1991 from when he ordered it. I have every manual and spec sheet for everything along with a dated diary of sorts of every repair done on the visssel since it was new so I'm not worried that i bought a lemon. Just about everyboat ive owned...when a mechanical problem arrises it usually has something to do with cooling and the rest of the problems turn out to be electrical. Im just new to inboards so since i do almost all the work myself, i wan't to understand the system as well as repair it correctly. Wich leads me to ask questions to other carver owners. Who better to get info from.....right? I think it was put away for the winter with some water in that riser and it cracked at a weak spot in the casting. I just how tday will fix the problem. Im Going to change the impellers on both motors just to be safe. I don't know when they were last done and since I have new impellers in that hold it isn't costing me anything.
- mjk1040
Users browsing this forum: No registered users and 50 guests
