1973 Monterey 2585 bringing her back to life
- lrfickau
- Vessel Info: 1973 Monterey 2585 OMC 225hp single IO
"SEA STAR" - Location: Lake Geneva Wisconsin
- Been thanked: 5 times
new member with a 1973 Monterey 2585
How do you add a photo
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: new member with a 1973 Monterey 2585
There are other sites one can use but I like this one.
Good luck with your restoration.
Get that engine running as soon as you can. Get rid of the fuel and start with fresh stuff. Replace fuel filters, and while she might start and run, you may want to consider having the carb rebuilt to avoid issues later.
The distributor cap, rotor and points will probably be corroded so take a look at those also, and replace the plugs while you're at it.
Replace the water pump impeller as it would have taken a bad set by now, otherwise it might fly apart shortly after start up.
Change the oil, filter, and gear lube. Don't know the brand of drive you have but check the bellows too.
A lot of systems to consider here but I'd get the engine going first before I put money into anything else.
Has she been outside uncovered all this time? Did you get a survey?
Keep us posted. Can't wait to see some pics.
- lrfickau
- lrfickau
anybody have a throttle control. Anything else you would like to see. I could take a photo.
Like Fred said, start a thread in the "The Project Center" section so we can follow your progress.
- RGrew176
- lrfickau
- RGrew176
lrfickau wrote:Source of the post FYI guys this one is a fiberglass hull with the lines of a wood one. any one care to donate a OMC shop manual. would help me fallow through with the above suggestions.
I sure thought it was a woody, certainly looked like one in the pics. Nice boat.
