Carver 405
Soggy dollar
Topic author - Scurvy Dog
- Vessel Info: 1989 carver 405
Carver 405
- Been thanked: 646 times
Re: Carver 405
What engines? I have crusaders xli with tbI injection. What's your definition of manual priming mean? Pouring gas in tb? With tbi when you first turn on the key the fuel pump should run for 2-3 seconds hAve you verified whether you can hear this happening then? You should be able to cycle the key on a few times to prime it at least right now.until the problem is found. Maybe pressure regulator or check valve in fuel pump? Fuel pump relay? Low fuel pressure maybe. Vapor lock maybe on carb engine. Really strange both engines are having this problem
- mjk1040
- Been thanked: 246 times
Re: Carver 405
- Been thanked: 601 times
Re: Carver 405
My merc motors have the "cool fuel" set up with fuel pump being cooled by raw water. I don't think the crusaders have this. My guess is they (fuel pumps) are hot and don't want to run, maybe even have a high temp switch? Try putting a couple cool wet rags on the fuel pumps about five or ten minutes before you are ready to start. If they start, at least you know what the problem is. How to fix it, different story.....Keep the blowers on, add extra blowers on a t-stat????
- Has thanked: 468 times
- Been thanked: 1765 times
Re: Carver 405
Are you sure it's a lack of fuel that is causing this issue? When you say you are losing the prime, how do you know? And how are you priming?
Re: Carver 405
Sorry.
Re: Carver 405
