405 stbd Velvet drive 20-01 noisey
405driver
Vessel Info: 1998 Carver 405 gas
Has thanked: 37 times
Been thanked: 6 times
Postby 405driver » November 20th, 2016, 10:58 pm
My starboard drive train is making noise somewhere, It's hard to tell where it's coming from. The noise seems to be in the transmission. It only does it while in gear, neutral is quiet. I think I will start with the engine and move back through the plate and then the drive itself. Any suggestions would be greatly appreciated.
Re: 405 stbd Velvet drive 20-01 noisey
Postby Viper » November 21st, 2016, 7:06 am
Those are all good things to check. What engines do you have? You also want to ensure RPM isn't too low. Also possible flex plate.
405driver
Postby 405driver » November 21st, 2016, 9:51 am
Our boat has Mercruiser 454 Mag MPI Horizons. I tried pulling a few plug wires one at a time out of the distributor but I couldn't hear any difference. Will an old dwell/tach meter work on this motor? Thought I might see a drop in RPM with each wire pulled.
I have only had this boat for about a month and am busy solving little issues as I find them. I was looking at the engines a few days ago and noticed that almost all of the bolts in the couplers were loose in some degree. The surveyor seemed to have missed quite a lot of items. I haven't tried since I tightened the coupler bolts, but the port bolts were just as loose as the stbd and it makes no noise. I'll try it in the next few days and post something.
Can one see the flex plate through the inspection hole?
I'm a retired airline pilot, both sides are supposed to sound the same...:-)
