Windlass
mibeaulieu
Topic author - Scurvy Dog
- Vessel Info: 1992 Carver 638 Santiago
- Has thanked: 3 times
Windlass
1. Windlass - I was thinking about the Maxwell RC8-8.
Anyone use the Maxwell? The boat is all wrapped and I don't have access to the bow to measure anything. Anyone know if this will fit the Santego? Thoughts on the quality. Right now the boat has a "Good" all rope windlass but it won't accommodate any chain so I was thinking I would swap them out.
2. Looking at adding Radar and the Simard GO9 XSE seems to offer a ton of value for an 3 in 1 solution. I would potentially fish off this boat a couple times per year. Most likely in Long Island Sound. In addition, I can see a few trips to Block Island. The boat has a GO7 right now.
Although this will be my third boat - it's my first yacht per se and just trying to get a few things out of the way for the winter.
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Windlass
Re: Windlass
Remember that if you don't already have one, install a chain stopper so that your anchor doesn't deploy accidentally and so that the load when on anchor is on the stopper and not the windlass itself.
mibeaulieu
Re: Windlass
bud37 wrote:Welcome to the forum........Just a suggestion, but why not stick with Good, they are a family outfit, make real good stuff and all in the USA ( New Jersey) unlike a lot of others ( motors etc) ....I had one in the last boat and was quite pleased with the quality ......perhaps they could recommend how to retrofit your existing....well just a thought considering what you already have.........
My first thought was to get the Good retrofitted to accommodate for a chain. Good is a fantastic company but this windlass can't be upgraded for any length of chain.. so I think its better to replace and sell the Good. I was going to buy a couple things over the winter to get the boat ready for spring.
Re: Windlass
Re: Windlass
http://www.maxwellmarine.com/support_manuals.php
click Power and Sail, then RC Series, then RC8, and scroll down to the cable size selection chart on page 15 and you'll see the requirement for the RC8-8 is a minimum 4 AWG wire for a maximum 35' run of cable, on a 12 volt unit. That length is the total of both the positive and negative wire together, from the source to the windlass and back to the source. If the breaker is going to be installed in an easily accessible area like the electrical panel, then your positive wire will be much longer than your negative one. That's okay, you just need to take the total length of both wire runs to determine the wire size that you'll need.
