Carver 404 Flybridge bimini to hard top?
PJHoffnet
- Has thanked: 55 times
- Been thanked: 18 times
Thanks in advance for any insights.
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Carver 404 Bimini to hard top?
T-Merc 350 Mag MPI (300hp)
PJHoffnet
- Ramsport47
Re: Carver 404 Flybridge bimini to hard top?
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
They have 2 tops, the only difference being that that the upgraded one has a "drop ceiling" style ceiling which yiou can add pot lights to or electronics boxes. The fit and finish was factory.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
PJHoffnet
Thanks to all who replied - now back to our regularly scheduled programming.
- cpoint
- Has thanked: 208 times
- Been thanked: 31 times
So finally designed something and thinking of available materials, as well as anything that I can easily structure. I am thinking about using the frame that's already there that holds the canvas top. I have not figured out solution for the frame, but the 4 sections seen in the images would be made out of POLYCARBONATE TWINWALL - WHITE. This is super light and very strong. The frame (I mean the edges, seen as white in the images) will be either fiberglass or some other light, strong material that I can also bend length wise to boats shape so it does not look like it does not belong there. It would need to follow the lines. So any ideas on material (for the sides/frame) would be appreciated it. I think I can use foam,epoxy, fiberglass and paint to give it look and match to rest. But I am trying to avoid fiberglass part building as I never did it. Maybe I can send plans to some manufacturer who can quote me a price for the 5 pieces. I am sure it will be ridiculous price.- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- cpoint
Cooler wrote:Source of the post Cpoint - look around for a fiberglass shop in your area. Show them the plans, give them a budget. You may get surprised. Submit to a plastics shop also. Amazing results with some plastic hybrids. Atlantic Towers does great work, but they are expensive. Even their stainless radar arches are crazy expensive, but they can get it, so they should.er
Yeah Cooler, if money is no object there are places that does excellent job, but money is unfortunately object
I will try your suggestion, with some local shops, maybe if they have no business they may be desperate enough...
- Cooler
