Fresh Water Tank clean up?
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Fresh Water Tank clean up?
Works great for those hard to reach spots in your bilge as well.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Fraser
- tonyiiiafl
- mjk1040
- Been thanked: 246 times
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
- feeez
I have always thought it would a great set up to plug into shore water and through some valve system have it fill the tank as required without the tank having to be pressurized. Having said that last season our Marina water although potable had a "bleachy" odour about it..... Just rambling on here looking forward to spring!!!
What is the full name of the Camco Product??
Cheers
Fraser
- Has thanked: 469 times
- Been thanked: 1765 times
It's a great product IMO and I've used a few different ones. I've tried both powder and liquid products. The problem with some powder products is that they have to be dissolved first before you pour them into your tank or they end up clogging all your faucet strainers. Warm water helps break it down but you have to agitate for a while...time consuming.
The first time I used the TastePURE on my own boat was when I first bought the boat so it was part way through the season. The system had already been cleared of plumbing antifreeze, rinsed, and in use for some time. I ran the product through the system and let it stand overnight. When I rinsed the following day, you'd think it was plumbing antifreeze that came out, it was so pink! It had stripped the lines of antifreeze stains. Given that I didn't know whether the previous owner had ever done this before, I wanted a very concentrated mix so I added the entire gallon to the tank and just enough water to ensure it covered the entire system less the hot water tank. I use it at every Spring commissioning now.
Good stuff.
- mjk1040
In our marina, the shore water is run around in black water line exposed to the sun. Some days it takes for ever to get cold fresh water? Thus we always haul in drinking water from home or the spring water from the store for consumption. So in all reality should we consume the ice in the ice maker? What I do know is this Camco product works great. Mike
- Has thanked: 598 times
- Been thanked: 1281 times
Fraser, you should check , I know our marina is on a well, maybe so where you are as well, not sure but I don't think city water runs up Champlain.........
