Generator
Topic author
scoobychonx
Vessel Info: 1991 carver 36 aft cabin twin cummins
Has thanked: 5 times
Generator
Postby scoobychonx » January 9th, 2017, 7:25 am
Hi all. Ive got a new install generator in my 91 3608 my question is I'm looking into the change over switch options but also been looking into the original relay box if this is originally used by carver your inputs would be appreciated and how you change over from grid hookup to generator
Regards Lee
Been thanked: 490 times
Re: Generator
Postby waybomb » January 9th, 2017, 12:10 pm
The relay box automatically switched sources. Would not hurt to replace them every once in a while.
I'd rather have the setup that was on our 4207 - the mains (genny and line) were adjacent to each other and had a sliding cover that only allowed one to be the source.
Re: Generator
Postby Viper » January 9th, 2017, 2:31 pm
waybomb wrote:Source of the post....I'd rather have the setup that was on our 4207 - the mains (genny and line) were adjacent to each other and had a sliding cover that only allowed one to be the source.
++1
The older models utilized the existing shore line breakers and incorporated a rotary switch for selecting the source.
Re: Generator
Postby tomschauer » January 9th, 2017, 9:53 pm
my 355 has the auto switch over relays. It works just fine but I would be happier with the lock out breakers, only two parts to fail.
