Boat is in really good shape cosmetically, mechanically and electrically wte of a lot of blistering below the water line (time and $ consuming, but nothing that points to a disaster).
The only real problem noted in the survey that I'm concerned about is the turbo chargers on both engines. Both showed excessive rust and corrosion during the pre-underway survey, and during sea trials we couldn't bring the engines above 1800 RPM, so the turbo chargers never kicked in. The surveyor and I figured the turbos were frozen shut and passed that info on to the seller as a 'must fix' followed by a re-survey.
Seller's broker came back after having her engine guy look at it and said turbos are not frozen, but (and forgive the wording here, I didn't take the call and am working off the notes my wife took and her recollection of the conversation) that the pitch of the props are wrong and that's why the turbos never got a chance to kick in. They said they'd haul out, 'fix the pitch', (I can only assume they mean change props) and be ready for re-survey soon.
Ok, now we're not talking about a destroyer with veritable pitch propellers here, and I suppose it could be as simple as changing to a correctly pitched propeller for the engine.
Stbd and port turbos
Prop, probably doesn't help, but only one I had
Thoughts? - Thanks in advance
