drain plug on santego 34
Guy
Vessel Info: 1989 santego 3467.
BRIGADOON
Has thanked: 19 times
Been thanked: 2 times
Postby Guy » January 25th, 2017, 9:15 am
hello all,
I need some help, new to the santego, drain plug was the home depot rubber stopper type that expanded when tightened screw. That scares the hell out of me, and there are two drain holes!!!!
the threaded insert is about one inch pipe thread but the bushing I bought won't thread.
any ideas of what I need to do before filing in with fiberglass and starting new
thanks
Guy
Re: drain plug on santego 34
Postby tomschauer » January 25th, 2017, 1:13 pm
Normally these should be standard pipe thread, usually 3/4 or 1". Maybe someone stripped it somewhere along the line. You could try running a pipe tap through the threads.
Postby mjk1040 » January 25th, 2017, 6:45 pm
Yep, what Tom said, try re-tapping it first. If it feels a little lose after tapping, wrap the plug with Teflon tape or even electrical tape to tighten it up. If you are unable to re-tap it, may be another expandable plug in the bottom hole too. Mike
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » January 26th, 2017, 5:58 am
The older Carvers used a large "t" handle plug made by Perko in their hull bottom. You can still buy the replacement plug for it, but it is expensive. The T handle is to aid in installing and removal.
Kenny
T-Merc 350 Mag MPI (300hp)
Postby Viper » January 26th, 2017, 7:04 am
A picture would help. I'm not following you when you say you bought a bushing. I would consider a bushing to be the smooth brass piece (no threads) in the hull to accommodate the expanding rubber plugs. That style of hull fitting isn't what should be there. It should be a threaded fitting. Check out the pics below...
https://www.google.ca/search?q=t+handle+boat+plug&espv=2&biw=1522&bih=732&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjIy9DK4N_RAhXo8YMKHVLuA_AQ_AUIBigB#tbm=isch&q=brass+t+boat+drain+plug
Ramsport47
Postby Ramsport47 » January 27th, 2017, 6:04 am
http://www.perko.com/catalog/underwater ... rain_plug/
This is what came in the boat from the factory...
Kenny
Users browsing this forum: No registered users and 63 guests
