Cummins 370 6TBA raw sea water pump
Topic author
Tomion
Vessel Info: Carver 530
Been thanked: 2 times
Postby Tomion » February 8th, 2017, 2:08 pm
Its time to replace my sea water pump impellers, they are 4 years old. Ugh! I have seen an upgrade replacement pump from Seaboard SMX 1730. They suggest on their add the stock pump is inferior and prone to failure. They are $750 compared to the stock pump of $430. Has anyone had to replace a failed pump on their Cummins 370 6BTA. My 2001 engines have 570 hour on them and about 100 hours on impellars. Thinking about putting spare pump onboard as well as impellar. Thanks
Re: Cummins 370 6TBA raw sea water pump
Postby mjk1040 » February 8th, 2017, 8:52 pm
Are these in fresh or salt water? Your call, but I would wait until after I changed the impellers and did a visual on the pumps. If you show signs of possible failure or excessive internal wear, I would then contemplate my next move, replace with originals or upgrade them? Your $$, your call! Mike
Midnight Sun
Vessel Info: 2007 Carver 41 CMY D6 370's
Been thanked: 3 times
Postby Midnight Sun » February 9th, 2017, 6:07 am
I would definitely agree. Rather rare for a pump to wear out unless the water you are in is very dirty and you have thousands of hours on the clock. 4 years and no issues, doing preventative maintenance sounds quite good and no indication of wear IMHO.
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 29 times
Postby CYO Admin » February 9th, 2017, 6:15 am
The Sherwood pumps are junk. I replaced mine with the ones from Seaboard and had zero issues with them.
Mystic144
Postby Mystic144 » April 21st, 2017, 6:20 pm
Keep in mind its not the impeller that fails but rater the seal on the shaft that drives the pump.
When it fails it will take out the gears in the front of the engine.
This is what is considered complete engine failure.
Postby Viper » April 21st, 2017, 6:28 pm
Mystic144 wrote:Source of the post....the seal on the shaft that drives the pump.
+1
Replaced a Cummins 2 years ago for this very reason.
ScubaPete
Vessel Info: 2002 Carver 406
Cummins 6BTA 330's
Postby ScubaPete » April 27th, 2017, 11:19 pm
My Cummins 330's have the stock Sherwood pumps. The boat is a 2002 Carver 406. After 15 years and 800 hours (550+ in salt water) both are doing just fine with no leaks, drips, or weeps. All I have ever done is change the impeller every 100-150 hours.
I keep hearing that the Sherwood pumps are junk, but that's not true for me.
simple interest
Vessel Info: 2000 406 Carver and a few other smaller boats
Postby simple interest » June 27th, 2017, 9:29 pm
What is normal life expectancy for impellers when used in saltwater?
Steve M
406 Carver
John Easley
Vessel Info: Sold a 1986 42' Chris Craft Catalina. Looking for a 1999-2006 530 Voyager Pilothouse.
Has thanked: 5 times
Been thanked: 8 times
Postby John Easley » July 10th, 2017, 9:06 am
ScubaPete wrote:Source of the post My Cummins 330's have the stock Sherwood pumps. The boat is a 2002 Carver 406. After 15 years and 800 hours (550+ in salt water) both are doing just fine with no leaks, drips, or weeps. All I have ever done is change the impeller every 100-150 hours.
Agreed. I have the same engines with stock raw water pumps. The impellers are changed almost religiously at 100 hours and the 20 year old pumps are going strong. This boat has been in salt water its entire life.
Danv35
Vessel Info: 1998 Carver 400 CMY twin Cummins diesels
Postby Danv35 » April 11th, 2018, 10:25 am
How difficult is it to change out the port impeller? Cummins 330hp 5.9
