Carver 400 MY engine RPM issue
hausherrs
Vessel Info: 1996 Carver 400
Has thanked: 5 times
Been thanked: 10 times
Postby hausherrs » February 20th, 2017, 8:11 am
Engines: Cursader 454 XLi
This past weekend I took the family out into the bay and the stbd engine wouldnt go over 2500 RPM when I had the port at 3000. I backed the port down to 2500 and the stbd would follow it down regardless of throttle. When I throttle up the stbd it would drop 200 rpm.
No smoke or strange noises. Temps and oil pressure were normal.
I have a set of fuel filters I need to put on. And im planning on sending off the injectors for cleaning.
Any ideas?
Thanks,
Steven
Re: Carver 400 MY engine RPM issue
Postby g36 » February 20th, 2017, 9:52 am
I have 454 xlis on my carver 405. You have 3 fuel filters per each engine. The first is the oberg (ufo) which is a screen and can be opened and cleaned. When i notice any rpm issues I look here first I do have some junk in my tank and have to clean this a couple or so times a year. I would check it and clean it. Next is the water seperator and then the inline filter by the tbi it may be a good idea to change them I f you don't know the last time they were done but hold off on sending out the injectors. The oberg could easily be the culprit and once cleaned I would test drive it before doing any other filter.
Postby g36 » February 20th, 2017, 10:01 am
In case you didn't already know the oberg is black and a pancake or ufo shape with a bolt running through it. Put a basin under it to catch the gas and open it by loosing the bolt. It seperates in 2 pieces Remove the mesh screen and clean the screen then reinstall it
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Postby dsolo » February 20th, 2017, 2:35 pm
Make sure gas valves are in the off position. I know from experience.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby mjk1040 » February 20th, 2017, 3:05 pm
So Viper, you think Crusader or Carver anticipated crap from the fuel tanks in these models? And what filter is at the throttle body? Mike
Postby g36 » February 20th, 2017, 3:12 pm
So. I'm not viper but here is the filter at the throttle body
https://www.amazon.com/gp/aw/d/B002XKFM ... PDKIKX0DER
hausherrs
Postby hausherrs » February 20th, 2017, 3:41 pm
Thanks for the info guys.
Ill pull that filter apart this evening. I have a set of those pricy TB filters. They just need to be installed.
One thing worth mentioning is that engine RPM seems to get lower and lower every time I take it out. Junk in the filter would make sense.
Thanks,
Steven
Postby Viper » February 20th, 2017, 3:51 pm
mjk1040 wrote:Source of the post ...you think Crusader or Carver anticipated crap from the fuel tanks in these models?....
This was a Crusader thing. Can't remember the recommended service interval off hand but I check them whenever I preform fuel service on a Crusader that has them. I find if they have never been serviced, they can get so bad that I don't even bother cleaning them and replace instead. After that, if serviced regularly, a cleaning is all they need. Crusader recommends they be checked within several hours run time when the vessel is new as it's likely to trap debris from a new tank/vessel build. But I suspect that's rarely done from what I've seen, which is unfortunate as it's the first line of defense in the system if memory serves me correctly.
hausherrs
Postby hausherrs » February 20th, 2017, 8:14 pm
Here are a couple pictures. A good amount of blockage...
Users browsing this forum: Google [Bot] and 18 guests
