Circuit breakers on 1987 42 aft
The Dash
Vessel Info: 1987 Carver 42Aft Cabin
Has thanked: 3 times
Postby The Dash » February 22nd, 2017, 1:10 pm
:help: We need to replace a couple circuit breakers, the main breaker for accessories and pumps. Panel is 12VDC Any idea where we can purchase from?
Been thanked: 490 times
Re: Circuit breakers on 1987 42 aft
Postby waybomb » February 22nd, 2017, 6:22 pm
Whenever I needed one when I was i Wisconsin I'd be going to Kendor's in Franklin Wisconsin. They have an Ebay presence as Greatlakesskipper.
They buy a lot of surplus from Carver, Cruisers, and others, along with selling new stuff.
Give them a call with a description.
My 4207 also had a light for each breaker. Those would go bad and they had those as well.
Postby tomschauer » February 22nd, 2017, 7:23 pm
West Marine, and most any marine supply store should have them. A camper/ RV store may have them cheaper?
Been thanked: 1310 times
Postby bud37 » February 22nd, 2017, 9:19 pm
Try Blue Seas Systems, big assortment of marine electrical ........ :beergood:
Postby Viper » February 23rd, 2017, 9:22 am
Someone can probably confirm but it's likely Carling breaker. Try this link and scroll down to the breaker section and series that matches what you have. As mentioned above, any marine retailer should be able to get what you want. There should be a label on the side of the breaker with the specs needed to order the proper replacement.
http://www.carlingtech.com/marine
The Dash
Postby The Dash » February 24th, 2017, 10:47 am
Thank you all so much. :down:
