Forward shower sump in 405 my
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Can I assume the sump's manifold must be trimmed as the flanges get used? Perhaps this was a factory mistake?
Confused
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Been thanked: 654 times
Re: Forward shower sump in 405 my
g36 wrote:Source of the post ....the size hose you are describing sounds like this is the hose for the bilge pump....
Good possibility.
Do you see any wiring there?
- dsolo
454 EFI Crusaders
g36 I do have a bilge pump in the area, it is aft of the sump. The little water in the bilge is clear and bilge has no evidence of ever having brown water in it. I will find where the bilge is pumped to.
The aft head sink drains directly through the hull. It has a loop in the hose and attaches to a plastic through hull fitting.
I do not have a clam shell covered drain. I will try to locate where the drain goes.
I have access to the AC unit and will check where the drain goes with Viper's suggestion.
Will keep you updated once I am at the boat next week.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
What I mistakenly thought was the discharge hose is the AC drain pan hose.
Also found the shower floor drain connection had the sump's flange melted and calapsed inside the hose and clamp. There was some history of leakage. (Lucky the forward head was not used for showers.) Someone must have applied heat to the hose while pushing onto flange?. It is 1 1/8" hose. Hose could take alot more heat than the plastic flange. Always heat up a hose then install on cool flange.
Ordered new Atwood shower sump. Will make a discussion on replacing lines all lines.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 602 times
- Been thanked: 1311 times
- mjk1040
- Been thanked: 248 times
mjk1040 wrote:Source of the post...some people shouldn't own a boat! But then the repair guys would all be out of a job...
I can tell you that sometimes it's just not worth it, I'd rather not get the job! I much prefer doing work for an educated boat owner rather than one that doesn't have a clue about boats, their systems, and the potential dangers. They always seem to be the ones most difficult to deal with and then try to tell me how I should do my job. While some are a pleasure to share my insight/experience with, convincing others of something you know must be done or doing it a certain way can be futile at times. That's okay, pay me now or pay me more later I always say.
yuk
