Port engine spooling up slower than starboard.
Tomion
Topic author - Deck Hand
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
Re: Port engine spooling up slower than starboard.
You didn't mention replacing props but did you have an impact? If you did, did this symptom exist prior to the impact or only after?
How old is the boat? Are the engines electronically controlled? Is there any indication that the ECM/computer may be dictating the slow response? Any alarms? If you haven't already, it may be beneficial to get a tech in and hook up to the ECM and look for fault codes, and if applicable, update the software. Make sure all connections are clean and tight on the engine harness plugs. It's a whole new ball game with electronically controlled engines.
Tomion
Will check freedom of Turbo chargers and possibly swap them. Thanks
Tomion wrote:Source of the post....Racors look clean, were replaced a 100 hours back.....
How long ago was that time wise? The condition of the fuel filters will differ from running 100 hours in one year versus the same number of hours over 5 years. Given the cost of them, I'd replace them every year. They're your first line of defense. Ensure there is no water in the bottom of the bowls.
Tomion
Users browsing this forum: No registered users and 38 guests
