444 CPMY.
Foster15
Vessel Info: 2001 444 cockpit motor yacht
444 CPMY.
Postby Foster15 » April 8th, 2017, 3:54 pm
Hi. I purchased a 2001 444 last fall and had props sent out for scanning. I am told they are of Canadian manufacture (24 x 30) and the blades are not welded equal distance around hubs. Rear cutless bearings wore out in less than 400 hours.
Anyone heard of this issue?
Lots of $'s to replace.
Foster 15
444 CMY 2001
Racine, WI
Re: 444 CPMY.
Postby tomschauer » April 8th, 2017, 11:01 pm
It sounds like you are trying to say they were not balanced. No matter if they were manufactured in Canada, US or China, I would think if they were significantly out of balance you would have felt some vibrations when cruising. I would also think, props out of balance could shorten the life of the cutlass bearings, but shaft alignment would also accelerate the bearing wear, with less noticeable vibration.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: 444 CPMY.
Postby Lyndon670 » April 9th, 2017, 12:23 am
+1
You would feel it while cruising. That being said, you did mention that you had just bought the boat, so you may not have noticed it as you wouldn't already have a baseline.
Also, as mentioned above - with no noticable vibration present, an incorrectly aligned shaft will take out cutlass bearings before props that you don't notice a vibration from.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Ramsport47
Been thanked: 59 times
Re: 444 CPMY.
Postby Ramsport47 » April 9th, 2017, 7:24 am
+1
Also, to add to the conversation. Prop blades are NEVER welded on. The entire prop is molded as one piece. If a prop shop told you they were "welded" in the wrong position, I would look for a new prop shop. It sounds more like they want to sell you a new set of props than repair what you have.
Kenny
T-Merc 350 Mag MPI (300hp)
Brazil
Hugo
Been thanked: 23 times
Re: 444 CPMY.
Postby Hugo » April 10th, 2017, 2:23 pm
No welding there, molded like Ramsport said.
Also with 24X30 on that you are most likely over propped. Make sure you are reaching 50-100 RPM over manufacture WOT or the motors are next.
