I turned up the seacock on to de-winterize the AC unit. then I went to turn power on and all well. Then I switched the AC water pump and breaker tripped. Did it 2-3 times same. There is quiet a bit of rust, not sure that has anything to do with, maybe loose wiring? It worked flawless last season. So there is power, when I turn AC power on power comes on behind the kitchen table. But trips when I turn the water pump for AC on.. Do I need to replace the whole pump? or the thing hanging from it? see pictures. Thanks guts in advance.Welcome to Carver Yachts Owners Forum
AC Water Pump tripping breaker
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
I turned up the seacock on to de-winterize the AC unit. then I went to turn power on and all well. Then I switched the AC water pump and breaker tripped. Did it 2-3 times same. There is quiet a bit of rust, not sure that has anything to do with, maybe loose wiring? It worked flawless last season. So there is power, when I turn AC power on power comes on behind the kitchen table. But trips when I turn the water pump for AC on.. Do I need to replace the whole pump? or the thing hanging from it? see pictures. Thanks guts in advance.- g36
- Been thanked: 654 times
Re: AC Water Pump tripping breaker
- mjk1040
- Been thanked: 248 times
- waybomb
- CYO Moderator
- Been thanked: 490 times
Disconnect power.
Take a screwdriver and short between the two connectors.
Now pull the wires off.
Get a an old analog meter like a Simpson..
Set to the middle range of ohns.
While watching the meter, touch both leads to the capacitors posts. Does not matter with which lead to which post. A good cap will show the meter move to the right, then sweep back to the left as it charges.
Now short the leads out again, if that's a good cap it will shock you if you don't short it out.
Note check each post to the case of the cap.
Should not see continuity.
I bet the cap is bad and can be bought at almost any heating and air conditioning shop.
- cpoint
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- cpoint
By the way, did you check to see if that unit is ignition proof?? On a tip from a distributor, I confirmed that not all the models of that type of pump are. Since that tip, I always check now and have found a few installations that were not safe for a gasoline engine compartment. To err on the side of caution, I go with sealed units now. Not only is there no guessing if they're safe, but they're submersible, so if you get water on them for what ever reason like during winterizing a system, you don't have to worry about it.
